ALE mesh-smoothing by a simple average?
Old   October 31, 2007, 19:23
Default ALE mesh-smoothing by a simple average?
jinwon park
I am solving 2D compressible flow problems. In doing, I need to adjust the fluid mesh in time. There are a number of mesh-smoothing schemes. Among them, I preferred to use the simple averaging scheme due to its simplicity. It is
x_new(i)=1/N*SUM(x_old(k)) over all neighbors. In some literatures, the formula needs to be iterated through few steps. My guess is that the procedure be like the solution method for the laplace equation.
My questions are that
what the convergence criteria for that equation is,
whether it must be iterated through few steps.
,for two-dimensions and whether each dimension is separately
iterated or both dimensions are iterated together. Is there
any good sample code or reference for ALE-mesh-smoothing?
Thanks in advance.
I now have no iteration loop to check the convergence of mesh-smoothing. --- Sample codes ---- DO 100 i=2,nnx-1
DO 100 j=2,nny-1
ip=nnx*(j-1)+i
ie=nnx*(j-1)+(i+1)
iw=nnx*(j-1)+(i-1)
in=nnx*j +i; inw=nnx*j +(i-1); ine=nnx*j +(i+1)
is=nnx*(j-2)+i; isw=nnx*(j-2)+(i-1); ise=nnx*(j-2)+(i+1)
temp(ip,1)=(temp(ie,1)+temp(iw,1)+temp(in,1)+temp( inw,1)+temp(ine,1)+&
temp(is,1)+temp(isw,1)+temp(ise,1))/8.d0
temp(ip,2)=(temp(ie,2)+temp(iw,2)+temp(in,2)+temp( inw,2)+temp(ine,2)+&
temp(is,2)+temp(isw,2)+temp(ise,2))/8.d0 100 CONTINUE
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[ICEM] Using a hybrid mesh for a simple pipe Udio_NT ANSYS Meshing & Geometry 17 October 18, 2012 14:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
3D valve motion but no mesh motion with smoothing slaol2 FLUENT 1 September 22, 2011 18:06
