TEK cold plate
Old   November 2, 2007, 15:35
Default TEK cold plate
Danny
Hello, How to solve problem of cooling water time The water is water container and on cold plate (TEK)
Danny
Old   November 2, 2007, 23:20
Default Re: TEK cold plate
Ahmed
It depends on what exactly you want. You can either follow a lumped analysis (ten minutes at most- check heat transfer introductry books) or a detailed analysis that will require the solution of the energy equation
HELP! Flow over both sides of a plate. farocean97 Main CFD Forum 0 September 12, 2011 10:57
Need help on perforated plate with less than 2% open area sosososo1114 FLUENT 9 August 31, 2011 01:33
entrance of a flat plate mc Main CFD Forum 0 April 24, 2007 22:38
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 15:15
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 11:49
