CFD system config
Old   November 8, 2007, 03:29
Default CFD system config
hari
hi, I am doing car park ventilation system using fluent Am having grid cells of 14-20 lakhs.
i initially started my simulation with 4 GB RAM system having 32bit windows XP system was slow while doing meshing and i upgraded the RAM to 8GB now meshing is quicker but takes more time to export the mesh from gambit
should we have to go for 64 bit processor or what is the ideal config
thanks in advance
regards,
Hari V.B.
Old   November 12, 2007, 09:02
Default Re: CFD system config
JWilliams
I could be wrong, but I believe 32-bit XP only supports up to 3Gb RAM, so from upgrading from 4Gb to 8Gb should not have done anything. If you want to use more than 3Gb you will need to go to 64-bit.
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
CFD analysis on brake system design nilesh_shete Main CFD Forum 0 February 21, 2011 11:29
Treatment of ill-conditioned system of equations by CFD tools shreyash08 Main CFD Forum 0 August 4, 2010 10:13
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
