Waves halted by moving mesh
Old   November 23, 2007, 13:23
Default Waves halted by moving mesh
Piotr Czajko
Fellows,
My 3D numerical wave tank (built in COMSOL) doesn't work right, hopefully someone here can shed some light.
first question, Q: can anyone point me to a good source for the proper moving mesh displacement/velocity components in terms of fluid velocities?
The imposed moving mesh (on the 'free-surface') does not show waves propagating down the tank but they remain trapped (in time) within the first row of mesh elements.
/\_________ --> wave direction | | | | ------------
I have a gravity force on the domain, non-slip conditions on the end, bottom and side wall and a velocity profile on the left hand side straight from linear wave theory.
2^nd Q: Has anyone observed this? 3^rd Q: Why would a moving mesh be so stiff? 4^th Q: Does anyone have a better way?
Alot of questions, yes. Thanks for any help you can offer!
Piotr
Old   November 24, 2007, 03:00
Default Re: Waves halted by moving mesh
momentum_waves
Have you perhaps created a 'numeric' shock in the first cells? Your boundary/conditions may/or may not, actually be predicting a shock & locking your wave in that position.
Some solvers can cause this problem with wave-based simulations. Try changing your solver type, & reduce element dimension. Also, make sure you have the correct time-step to capture the wave flow.
mw...
<www.adthermtech.com/wordpress3>
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 23 August 6, 2014 03:50
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM 8 April 7, 2014 11:10
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Moving and deforming mesh paolo FLUENT 0 June 19, 2003 08:12
