November 25, 2007, 08:52 |
air properties - heat expansion?
I am doing a natural convection (air) calculation using Boussinesq approximation. The temperature ranges from 6 degree C to 37 degree C. What reference temperature and heat expansion coefficient should I use for a range of temperature? Is there any website where I can find the values? Thanks! phsieh2005 |
November 25, 2007, 09:17 |
Re: air properties - heat expansion?
A thought:
Locate an equation for coefficient of thermal expansion - if not a perfect gas. As I remember, for a perfect gas, beta=1/T (where T=absolute temp [K]) Let the simulation compute beta as it determines the T field. mw... (www.adthermtech.com/wordpress3) |
Problem with buoyancy and heat generation | Jaguar | CFX | 8 | May 12, 2011 18:54 |
heat conducting in a solid domain | Rogerio Fernandes Brito | Phoenics | 0 | March 18, 2008 17:23 |
heat conducting in a solid domain | Rogerio Fernandes Brito | Siemens | 0 | March 18, 2008 17:23 |
AIR molecular properties | Julie Polyakh | Siemens | 3 | January 5, 2002 16:25 |
