November 23, 2007, 12:23 |
Waves halted by moving mesh
Fellows,
My 3D numerical wave tank (built in COMSOL) doesn't work right, hopefully someone here can shed some light. first question, Q: can anyone point me to a good source for the proper moving mesh displacement/velocity components in terms of fluid velocities? The imposed moving mesh (on the 'free-surface') does not show waves propagating down the tank but they remain trapped (in time) within the first row of mesh elements. /\_________ --> wave direction | | | | ------------ I have a gravity force on the domain, non-slip conditions on the end, bottom and side wall and a velocity profile on the left hand side straight from linear wave theory. 2^nd Q: Has anyone observed this? 3^rd Q: Why would a moving mesh be so stiff? 4^th Q: Does anyone have a better way? Alot of questions, yes. Thanks for any help you can offer! Piotr |
November 24, 2007, 02:00 |
Re: Waves halted by moving mesh
Have you perhaps created a 'numeric' shock in the first cells? Your boundary/conditions may/or may not, actually be predicting a shock & locking your wave in that position.
Some solvers can cause this problem with wave-based simulations. Try changing your solver type, & reduce element dimension. Also, make sure you have the correct time-step to capture the wave flow. mw... <www.adthermtech.com/wordpress3> |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
