November 13, 2014, 00:30 |
Compressible vs incompressible flow
Mr. Lee
Rep Power: 12 |
I look at a compressible flow model for a gas through a long tube in the paper titled "Constructive Lyapunov Control Design for Turbocharged Diesel Engines" They model it as an lumped orifice model as in the picture. From the model, I see that regardless of p2>p1 or p1<p2, the flow direction doesn't change. This is not consistent with what I have with incompressible model where flow = sign(deltaP)*sqrt(deltaP)...
One thing I notice is that their equation (2.6) is well-known for compressible. However, as I understand two pressures used in the equation are different in concept. One is stagnation pressure while the other is static pressure. Hence, p1 and p2 used in the case p1<p2 of equation (2.6) cannot be used in the case p1>p2. Could anybody explain to me why and correct me if I am wrong here? Thanks |
Compressible viscous flow newbie: when NOT to assume incompressible, non-gas EOS? | Srh | Main CFD Forum | 0 | April 19, 2013 02:12 |
Cavitation in compressible flow | soni7007 | CFX | 3 | March 29, 2013 12:06 |
starting compressible flow from incompressible flow results | mihaipruna | OpenFOAM Running, Solving & CFD | 2 | December 3, 2012 10:02 |
Incompressible, Unsteady Cylinder Flow | startingcfd | Main CFD Forum | 1 | March 15, 2011 01:12 |
Incompressible and compressible flow | boris | FLUENT | 0 | February 20, 2002 03:08 |
