November 30, 2007, 15:54 |
Wave generation
Does anyone have experience creating water waves? I want to look at waves striking a dock piling.
I started by writing a function to vary the water height at my inlet using a simple sine function, the wave doesn't propogate downstream however, instead it reverses back on itself and after awhile disappears |
December 1, 2007, 11:52 |
Re: Wave generation
You need to specify more than a displacement as an initial condition for travelling waves. A left moving wave and right moving wave may well have the same shape (displacement) at an instant in time but they will have different particle velocities.By (presumably) specifying a zero particle velocity you have not specified any overall movement of mechanical energy in one direction or the other (think force*velocity). Often this will give you equal right and left moving waves (i.e. drop pebble in water) but if you are doing this at the boundary then your boundary conditions may well interfere.
need tutorial files(Simulation of Wave Generation in a Tank) | gholamghar | FLUENT | 45 | May 6, 2018 10:57 |
Looking for UDF files of the tutorial "Simulation of Wave Generation in a Tank" | seucj | Fluent UDF and Scheme Programming | 12 | August 21, 2015 05:52 |
Wave generation | The_Architect | FLUENT | 3 | August 16, 2011 03:39 |
Wave generation using open channel wave boundary condition | krishnaprasad | Main CFD Forum | 0 | March 3, 2011 21:28 |
need tutorial files(Simulation of Wave Generation in a Tank) | gholamghar | FLUENT | 0 | March 28, 2009 03:08 |
