December 8, 2007, 05:32 |
flow calculation in rotating blade passages
for a rotational speed greater than zero and when a) inlet boundary conditions are total temperature and pressure, in addition to flow direcition; b) outlet boundary conditions are static pressure; c) initial condition is set to a constant value; then the direction of the flow after a number of iterations is reverse and then diverges. Are there any hints to start the calculations and get converged solution? Thank you.
December 9, 2007, 22:09 |
Re: flow calculation in rotating blade passages
R u sure that the code is ok? and the outlet static pressure is right?
if yes. Plz change lower the outlet static pressure to get convergence. and then use that as new computations' intial flow field. |
blade induced flow simulation | Mehran | OpenFOAM | 1 | October 27, 2011 03:24 |
Reverse Flow at Rotating Pipe Outlet | vismech | STAR-CCM+ | 1 | August 11, 2009 10:38 |
Flow study through Turbine Blade passage | Subrata | FLUENT | 1 | May 4, 2007 11:28 |
Re: how to do this turbine blade passage flow nanl | manish | Siemens | 0 | January 12, 2006 11:37 |
Rotation flow calculation. | Hans | FLUENT | 0 | March 31, 2003 06:03 |
