November 25, 2014, 10:31 |
turbine simulatino
Sharon Wilcox
Rep Power: 11 |
Hi guys,
At the inlet of the turbine, I want to specify head and discharge (mass flow rate) in CFX; is there a way to do this? |
November 25, 2014, 16:43 |
Khalil M Khalil
Rep Power: 11 |
What is the turbine type you are working on?
December 24, 2014, 18:09 |
Sharon Wilcox
Rep Power: 11 |
I am simulating francis water turbine
December 25, 2014, 14:33 |
Hamid Zoka
Rep Power: 18 |
simultaneous setting of mass flow and pressure (head) at the inlet makes your simulation over constrained. unless you set pressure (head) at the inlet an mass flow as the outlet boundary condition. If so, you will have no control on outlet static pressure level.
regards |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
Using 6dof for 3D turbine rotation | mg.mithun | Fluent UDF and Scheme Programming | 8 | July 24, 2018 00:53 |
[TGrid] Water Turbine meshed in TurboGrid: Geometry and Topology issues | ama294 | ANSYS Meshing & Geometry | 12 | September 29, 2014 13:23 |
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 17:18 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 09:32 |
