help with modeling stratified flow in Fluent
Old   December 18, 2007, 04:55
Default help with modeling stratified flow in Fluent
I am trying to simulate stratified two phase (air-water) flow within a pipe using the VOF model in Fluent. The air velocity is 7.39 m/sec & water velocity is 0.039 m/sec I divided the inlet into two parts one for air & the other for water , the results being good for predicting the velocity profile but the problem I cannot see a clear interface between the phases and when I view the contours of volume fraction the pipe appeared filled with air only knowing that I use unsteady solver with implicit scheme for VOF so who can assist me with this request.
Old   July 22, 2009, 14:42
Michael Bruckner
michaelb is on a distinguished road
Hi Baker,
I currently have the same problem. Could you tell me if you managed to do what you wanted and how you did it? I guess it is only a problem in the way I specify the boundary conditions but I can't find out why it doesn't work...
That would be very helpful. Thanks in advance for any help you could provide.
michaelb is offline   Reply With Quote
Thread Tools
Trackbacks are On
Modeling the flow patterns in a membrane bioreactor for wastewater treatment tutorial shadyenany FLUENT 9 September 15, 2011 17:01
Compressible flow modeling in Fluent nikhil FLUENT 8 August 9, 2011 14:18
How do I select solver options for external flow over an aircraft by fluent? hadieliasi FLUENT 5 May 2, 2011 03:54
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 12:41
How Fluent treat the pressure term in imcompressible flow Ray FLUENT 1 May 24, 2000 16:50
