validity of SST k-w model
Old   December 13, 2007, 13:09
Default validity of SST k-w model
Usman
Is the SST k-w model valid only for incompressible flows? Thank you.
Old   December 14, 2007, 09:25
Default Re: validity of SST k-w model
Hatef
No.
Old   December 14, 2007, 12:42
ag
There are compressible versions of k-w around. You'll have to search for them, as I don't have any references off the top of my head.
Old   December 20, 2007, 16:39
James L Brown
Topic is covered in:
Turbulence Model Validation for Hypersonic Flows
J. Brown, NASA Ames Research Center, Moffett Field, CA AIAA-2002-3308 8th AIAA/ASME Joint Thermophysics and Heat Transfer Conference, St. Louis, Missouri, June 24-26, 2002
You need not couple the model with the mean flow eqs which can speed up the solver by quite a bit. SST model tends to give slightly high heat transfer (10 to 15%) but is quite robust. Remember to validate your implementation against expt. and also Van Driest II.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
SST turbulence model PCFD CFX 56 June 20, 2017 15:45
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
convergence problem of the SST and RNG k-e model for mixing tank ziyan7 FLUENT 0 March 8, 2011 06:13
CFX's DES turb model hardcoded with kw SST??? Phil CFX 2 January 7, 2008 20:01
