January 19, 2008, 13:02 |
Zero Diffusive flux
I am running an external compressible flow steady state laminar model.I have modeled air as a reacting gas consisting of N2,O2,N,O and NO in FLUENT. I was able to run the simulation until Mach 12 after that it diverges with the error that mass diffusivity is zero. I have modeled mass diffusivity of the mixture using kinetic theory and I have defined the L-J parameters for all the species. I also tried to model using multi component diffusion by modeling the diffusion coefficients as polynomials for the interacting pairs. I got the same error after Mach 12. warning: Mass_Diffusivity: invalid (zero) diffusivity Please check material properties. Please give your thoughts on what could be wrong.
Thanks, Subramani |
Diffusive flux in interMixingFoam | oswald | OpenFOAM Programming & Development | 28 | August 14, 2018 23:05 |
Problem setting with chtmultiregionFoam | Antonin | OpenFOAM | 10 | April 24, 2012 09:50 |
Zero Diffusive flux | Subramani Sockalingam | FLUENT | 1 | May 27, 2009 10:36 |
Help: diffusive flux BC at wall | Quarkz | Main CFD Forum | 7 | July 17, 2005 11:24 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
