Model/simplification for mid-hi Re flow?
Old   January 19, 2008, 19:43
Default Model/simplification for mid-hi Re flow?
Zozo
I'm going to work on moving airfoils at Re=10000 for my research. I'm reading on the literature and deciding which model I need to use?
Can someone comment on that? I've read ppl using reynolds averaged NS equation, turbulence models and adding numerical dissipation etc.
Do I need to use any of these for my problem? Or is the original NS eqn sufficient?
Thank you very much.
Old   January 20, 2008, 10:32
Default Re: Model/simplification for mid-hi Re flow?
gocarts
From the Reynolds number, I guess you are looking at subsonic speeds in air. You mention moving, which I take to mean pitching. Final assumption (bit of a stretch) is you're looking at 2D airfoil sections.
In terms of outcomes, I presume you'll want lift, drag and pitching moment - maybe also pressure co-efficient at various positions around the airfoil.
You could go with a RANS solver, or given you are likely to encounter laminar flow just the NS as you suggest.
However, before you do anything I would suggest investigating less compute intensive methods such as panel methods as outlined in Low-Speed Aerodynamics, Katz & Plotkin: http://www.amazon.com/Low-Speed-Aero...dp/0521665523/
In terms of 2D modeling you might consider Xfoil: http://web.mit.edu/drela/Public/web/xfoil/
If you want more reasons to try a panel method: http://www.symscape.com/blog/why_use_panel_method
Full disclosure: I represent <a href=http://www.symscape.com/>Symscape</a>: Computer-Aided Engineering for All
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
