covective boundary condition
Old   January 25, 2008, 09:05
Default covective boundary condition
Mani
Hi
What is convective boundary condition and how can i impose it? I am working on CFX 11. I am simulating a flow over an airfoil which must use covective boundary condition at the outlet. Thanks
Mani
Old   January 25, 2008, 13:50
Default Re: covective boundary condition
KYO
If I am not wrong, convective BC is the same as the Neumann BC... look for it in google... good luck...
Old   January 25, 2008, 16:38
Mani
I have no idea what Neumann BC is but i think know now what convective BC is! Its more like an outlet BC. It is used to prevent any sound reflection back in domain. Thanks for reply.
Regards Usman
Old   January 28, 2008, 06:39
sega
In general the convective BC declares that heat flux normal to the boundary is given by this equation:
q_n = alpha (T_inf - T)
q_n: heat flux normal to the boundary; alpha: heat transfer coefficient (maybe give, or you get it from Nusselt-Equations, or maybe it your task to calculate it ...); T_inf: Temperature of the farfield; T: Temperature at the boudary
You wrote something about an outlet BC. An outlet BC must be a given velocity normal to the boundary. Like this:
u*n_x+v*n_y = constant
u: x-velocity; n_x: component of normal-vector in x-direction
Correct me if I'm wrong.
P.S. How can I do linebreak in this forum?
Old   January 28, 2008, 18:24
Mani
Why do you need to do line break in this forum. Are you working with LES sega.
Mani
Old   January 28, 2008, 19:05
S. Gatzka
What's LES?
Old   January 28, 2008, 19:19
Mani
Large Eddy Simulation is a superior technique to traditional RANS modelling. RANS modelling is crap, if you are still using it, give it up. LES is taking over!
Mani
Thread Tools
Trackbacks are On
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 03:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
Domain Imbalance HMR CFX 3 March 6, 2011 21:10
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
