Pressure coefficient distribution
Old   January 9, 2015, 03:57
Exclamation Pressure coefficient distribution
reynolds_master is on a distinguished road
Hi! I have to compute the pressure coefficient (cp) distribution with the data obtained with a wind tunnel for a NACA0012 airfoil. The values are obtained in kPa and the Vinfinite in m/s.
The Pinfinite is 1013mbar. I've tried to convert the pressures (both) to Pa but then the cp is about ~120 and this is wrong. The values of the P obtained are about ~-0.035 for the upper surface. I'm using the formula attached.
Does anybody know which mistake I'm doing? I've googled the theoretical distribution and it is not even close so the problem is not about the tunnel.
THANKS!
reynolds_master is offline   Reply With Quote
Old   January 9, 2015, 15:39
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Don't know how you are recording the data and where you recorded -0.035 and what's your free stream velocity and what's your angle of attack. In fact, you didn't provide anything more or less but…
-0.035kpa=-35 pa
Assuming this is relative pressure and assuming your free stream velocity to be 10 m/s you have:
Cp=-35/(0.5*1.225*10^2)=-0.57 which is a reasonable value.
lovecraft22 is offline   Reply With Quote
Old   January 10, 2015, 15:33
-0.035kpa=-35 pa
I was considering the pressure given as the absolute one and it was the manometric one.... So dumb of me. Thanks!
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
how to plot the pressure coefficient distribution along the foil of the wetted flow super OpenFOAM Running, Solving & CFD 3 December 19, 2012 15:03
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 03:30
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
