File format - binary? (plot3d)
Hey everyone!
I have read online it would be better to save the flow fields, etc provided by my CFD code in binary format. I have spent some time trying to understand MPI-IO, but I am still having some issues. If I take a simple plot3d grid provided by NASA (http://turbmodels.larc.nasa.gov/flatplate_grids.html), how can I translate it to binary format for example (is it what they call "unformatted"?). I have tried to simply read the grid using a fortran code and exporting it using MPI-IO, but I don't know how to check if I exported the right thing or not! How could I do that?? Thank you very much for your help! Joachim |
yes, binary requires less storage then ascii data but as you pointed out it does not have the benefit that you can just look at the file. for that reason I really like the CGNS format as it writes all in binary (mesh, flow solution etc.) but there are a bunch of tools out there (some very useful tools are already packed together with the library when downloading it) that lets you look at the cgns file in a file browser kind of style.
anyway, can you post your code here that you use for reading the plot3D file(s)? and I assume you try to read the structured mesh? the (probably) easiest way to check that what you are reading is correct, is to store the coordinate in some simple mesh format (I would suggest the tecplot format, readable by tecplot, paraview and probably other softwares but I just know those two), it has a very simple header (specify what you are going to store, i.e in your case x, y (and z for 3D version), how many entries in x, y and z and the mesh type) followed by the actual data. here is an example file that you coulduse to adopt for your case TITLE = "3D Channel Example" Variables="X","Y","Z" Zone I= 5, J= 3, K= 2, F=POINT 0.0 0.0 0.0 1.0 0.0 0.0 2.0 0.0 0.0 3.0 0.0 0.0 4.0 0.0 0.0 0.0 1.0 0.0 1.0 1.0 0.0 2.0 1.0 0.0 3.0 1.0 0.0 4.0 1.0 0.0 0.0 2.0 0.0 1.0 2.0 0.0 2.0 2.0 0.0 3.0 2.0 0.0 4.0 2.0 0.0 0.0 0.0 1.0 1.0 0.0 1.0 2.0 0.0 1.0 3.0 0.0 1.0 4.0 0.0 1.0 0.0 1.0 1.0 1.0 1.0 1.0 2.0 1.0 1.0 3.0 1.0 1.0 4.0 1.0 1.0 0.0 2.0 1.0 1.0 2.0 1.0 2.0 2.0 1.0 3.0 2.0 1.0 4.0 2.0 1.0 in your case, if you have the 2D mesh, just get rid of the "Z" variable, the K entry on the next line (and of course remove the third coordinate column) I, J, K are the number of coordinates in x,y,z direction. in my simple example you see that i have x ranging from 0-5, y from 0-2 and z from 0-1 (all incremented by 1) so i hope this will give you an easy way to write your coordinates to a file and easily check if what you have is correct. leave F as point. hope that helps |
Thank you for your answer! However, I am still having some issues with MPI-IO. I have read that all lines in the file were supposed to have the same length, so that I don't know how to handle the first lines.
For example, in the plot3d format, I can write the x, y, z coordinates, but I don't know how to add the first two lines with the number of blocks and grid dimensions... Would you know how to do that? Thank you very much! Joachim |
I think I understand your problem now, I have unfortunately not too much experience with MPI IO. However, what you could try is to first open the file by only one processor (that is handled with the communication handle) and then have the rest of the processor append their data to the file.
so in pseudo code something like if(myrank.eq.0) then ! master processor call mpi_file_open(mpi_comm_self,...) ! mpi_comm_self refers to only the calling processor write(*,*) blocksize write(*,*) dimX, dimY endif call mpi_file_open(...) ! let each processor append their data call mpi_file_set_view(...) call mpi_file_write_all(...) I am not exactly sure if that works but I hope you get the idea and can play around with it, let me know if it works |
Thank you very much once again!
Actually, i tried this: call mpi_file_open (...) disp = 0 call mpi_file_seek( mpi_fh, disp, mpi_seek_set, ierr ) call mpi_file_write( mpi_fh, 1, 1, mpi_integer, stat, ierr ) call mpi_file_write( mpi_fh, (/2, 1, 1 /), 3, mpi_integer, stat, ierr ) call mpi_file_write( mpi_fh, (/0.2d0, 0.8d0/), 2, mpi_double_precision, stat, ierr ) call mpi_file_write( mpi_fh, (/1.2d0, 1.8d0/), 2, mpi_double_precision, stat, ierr ) call mpi_file_write( mpi_fh, (/2.2d0, 2.8d0/), 2, mpi_double_precision, stat, ierr ) call mpi_file_close( mpi_fh, ierr ) so that all the data are on the same line. I only considered two points in this case (in 3D), but it was correctly imported with Tecplot. I am now going to do it with the entire grid and I will post the code here if it works. |
Ok! I got it to work. Since it was kind of a pain, let me write it there for posterity. :D
The code reads a formatted plot3d grid (structured, single block), decomposes into domains, and write down everything in binary in a single file using MPI-IO. I hope it helps someone someday! Code:
program convertToBinary |
I have been working on the solution file now, but I am still having an issue with the overflow-plot3d format. The original plot3d format works just fine:
READ(1) NGRID Code:
offset = 0 Code:
READ(1) NGRID Code:
call mpi_file_write( mpi_fh, 1, 1, mpi_integer, mstat, ierr ) When I say that the code works, I mean that it can be opened with Tecplot (which recognizes the overflow format). I have also tried with a simple fortran (non-MPI) code, and everything worked just fine with both format. what could be wrong in my code?? Thank you very much! |
how do you calculate offset?
for the plot3d format, I write 4 integers and 4 double precision numbers, so that makes 4*4 + 4*8 = 48 bytes
for the overflow format, i write 7 integers and 15 double precision numbers, so that makes 7*4 + 15*8 = 148 bytes does that sound right? |
hm, i remember in the code that i was given, i had to change the offset value everytime i call mpi_file_write. now it is strange that it is working in the first example, in my logic you need to tell mpi i/o always where you want to dump your data into, hence the existance of the offset value.
can you try the following, for each mpi_file_write, can you calculate the offset first, then make a call to mpi_file_set_view and then do mpi_file_write, so that you have something like offset = 0 ! and then 4,8,12,16,20,24,32,40,48,56,64,72,80,88,96,104,112 ,120,128,136,144 call mpi_file_set_view(offset) call mpi_file_write(...) i don't know what mpi_file_seek does, maybe your structure is working with that call but the above should work just fine. |
mpi_file_seek(offset) basically tells the code to write at location offset. I tried to add the offset between each write statement,
offset = 0 |
the only think i can think of is that maybe the filetypes are wrong (i.e. the variables are declared as single precision but written in double precision (I don't expect that but that has caused for me sometimes some troubles writing to binary)) just for the sake of trying, could you use MPI_REAL as type? But to be honest I am more poking with a stick in the dark here ...
I have actually tried with this non-MPI code:
write(2) NGRID I would like to check whether the grid dimensions + entire header has been written properly, but I don't really know how to do that... Thank you very much for your help! |
if you just write a small sequential fortran code to read the file, or rather only the header, you should be able to read it, no?
well, it is kind of weird. I used the following code:
!-------------------------------------------------------------------------------- NGRID1 = 1 (ok) --- NGRID2 = 0 (not ok!) |
yep, i get the same. also if you look at the error tag ierr of the mpi call mpi_file_read, i get a very high integer value (335627796) though when enquiring about its nature with mpi_error_string the program throws a SIGABRT at me.
also, the file that is created with mpi_file_write has 17.2 GB! on my disk. when I swap the mpi_file_seek for mpi_file_set_view the file gets the correct size of 4 bytes, though i get the same error message and can't read the file. what i am suspecting is that mpi follows the c standard, i.e. starts counting at 0, while fortran at 1. so for example, in the code that i have, the code first reads the data into a temp array and then adjust the indexing, see code below REAL(MYTYPE) :: PHI(0:NCELL-1) c--U1 Velocity IOFFSET_FILE=0 CALL MPI_FILE_SET_VIEW(IFH,IOFFSET_FILE,MPI_MYTYPE,IFIL ETYPE, #'NATIVE',MPI_INFO_NULL,IERR) CALL MPI_FILE_READ_ALL(IFH,PHI,NCELL,MPI_MYTYPE, #MPI_STATUS_IGNORE,IERR) U1(1:NCELL)=PHI(0:NCELL-1) I've tried to fiddle around with that but wasn't able to get it to work. the error code for mpi_file_read only seems to disappear when you set the count to zero but then you would not be reading the file and that is not what you want. anyway, maybe that helps you in some way |
