January 22, 2008, 04:33 |
CFD packages for ProE
Hi
I'm trying to help a small company to identify a suitable CFD package to bolster their design efforts (they currently don't use any since their design process is based on bench-marking existing products). They specialise in vacuum and solenoid actuated flow control devices. Given their lack of experience with CFD the package should be as simple to use as possible. It should encompass CAD repair, mesh generation, pre- and post-processing and visualization in one interface. It must also be compatible with ProEngineer Wildfire models. I've been researching the market and NIKA's EFD.Pro seems to meet all of the above requirements. Does anyone know of any other packages that might be suitable, or has anyone had any experience with EFD.Pro or NIKA's other products? Any thoughts or suggestions appreciated. Thanks, Alasdair |
January 22, 2008, 08:08 |
Re: CFD packages for ProE
I'd suggest taking a look at CFdesign aswell. Should do everything they need judging by your description. They would be able to model the valve motion too, if they wanted to go that far. Depends what they are looking at doing exactly.
Hope thats some help Jon |
January 23, 2008, 13:10 |
star cd check with them about their expert system that reads proE files
January 23, 2008, 15:27 |
There is actually a pro/E plug in so you don't need to read native files as it works within the pro/E GUI, it uses STAR-CCM+
January 24, 2008, 00:23 |
Thanks for your comments
January 31, 2008, 14:10 |
Alasdair
You seemed to have left accuracy out of the requirement list? Maybe it is ok for your client to reach the wrong answer as long as it is done quickly, but usually this is not the case. Having a tool that your client can not rely on maybe of very little benefit. MD |
January 31, 2008, 23:50 |
Ummm... I thought the need for accuracy was implicit.
Not really sure what you're getting at MD? Are you suggesting NIKA's EFD.Pro is not accurate? If so, please explain. |
Display Modes | |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 20, 2015 00:40 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | September 13, 2000 05:48 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 18:25 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 05:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
