[ANSYS Meshing] Creating named selections in ANSYS |
January 12, 2011, 23:02 |
Alvin Yeo
I had some issue on creating different sections on my fluid model. As you can see from the picture, I would like to create a new named selection on the section as pointed by the arrow but was unable to do so as the cylinder is a whole part itself. I had attempted to draw the sections separately but problems occurs when i attempted to mesh to model as the region of contact between the sections has very low meshing quality. My final goal in here is to create named selection on that section so that i can define a new boundary condition for me to use it at Fluent later. I would appreciate any help that is given [IMG]file:///C:/Users/ALVINY%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/ALVINY%7E1/AppData/Local/Temp/moz-screenshot-1.png[/IMG] |
January 14, 2011, 17:04 |
Imprint
Simon Pereira
Rep Power: 47 |
Create a sketch in the plane above the cylinder or on the surface of the cylinder, and then extrude the sketch... But instead of using the option to Add Material, choose "imprint surface" instead.
This will create a separate surface patch for you to select, but without actually subdividing the body... |
January 16, 2011, 06:17 |
Alvin Yeo
Problem solved. Thank you very much Mr. Simon!
March 18, 2018, 10:14 |
#4 | |
Alabi Abeeb Opeyemi
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Creating volume for two surfaces in Ansys | marbro | ANSYS Meshing & Geometry | 0 | May 22, 2010 11:13 |
ANSYS12 - named selections not transferred | enigma | Main CFD Forum | 7 | March 3, 2010 18:05 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
