February 20, 2008, 14:03 |
ICEM meshes inside my wing
Hi all,
I have a very complex geometry in two parts: wing and body (the root of the wing intersects the body). It is actually only a half bird geometry in a box domain. Strangely enough, I can make ICEM to mesh outside of the body, but it always meshes inside of the wing. It was written in the tutorials that I have to put a LIVE body point where I want the mesh to be, but it didn't change a lot. I tried several meshing setup. This is a screenshot, but I'm affraid it's not very clear http://documents.epfl.ch/users/s/se/...ages/icem2.png How could I enforce ICEM not to mesh inside this surface mesh ? Kindest regards |
February 20, 2008, 22:59 |
Re: ICEM meshes inside my wing
Delete the blocks inside the wing
February 21, 2008, 03:16 |
"Delete the blocks inside the wing "
You mean removing the cells manually ? I don't know how to automatically select all these cells... |
February 21, 2008, 05:47 |
sorry VORFN the block inside the wing, I did it like that
February 21, 2008, 07:02 |
I think there is a misunderstanding here .... Moving blocks to VORFN is for a hexa mesh, and I get the idea from the image that he is building a tetra mesh? Main thing is to make sure that your geometry is clean, i.e. if you run Repair Geometry, you should get red curves only, then put a body point outside the bird's body, and have another go. Make sure that the part of the symmetry plane that intersects the body has been removed. In fact, I am almost sure that is your problem.
February 21, 2008, 07:32 |
Charles and LBRS sorry for the confusion, I had always used ICEM-HEXA and advised based on that.
February 21, 2008, 09:09 |
Thank you a lot for the advides. It seems that a cleaning of the geometry (with a CAD software) really helps.
Also, I have moved the wing a little. Maybe there was holes in the wing outside of the body, which caused the problem. Now it works much better. Thanx ! |
PEM Fuel cell module meshes. ICEM vs workbench | aarvay | FLUENT | 24 | March 2, 2020 06:50 |
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench | aarvay | ANSYS Meshing & Geometry | 11 | January 12, 2017 12:51 |
[ICEM] 3d mesh around a wing using ICEM | artemis64s | ANSYS Meshing & Geometry | 6 | September 23, 2011 07:59 |
Different results from similar quality cfx and ICEM meshes | Nick R | CFX | 3 | January 17, 2011 07:48 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
