implementation of agglomeration multigrid
Old   February 27, 2008, 21:27
Default implementation of agglomeration multigrid
Shyam
I am currently implementing multigrid for unstructured grids (2d). I had successfully implemented a defect correction technique and obtained a good convergence rate for higher order solutions. Now, I am in process of implementing the agglomeration multigrid technique. I have some doubts regarding the treatment of coarser grids
1) How to determine the grid spacing (h) of coarser grid (arbitrary polygon) ? Or, how to decide the timestep to take in the coarser grid?
2) Restriction operation is done by injection (agglomeration). If I do a linear interpolation for prolongation, will it give a good convergence? Will the discontinuity at the coarse grid affect the convergence in the fine grid? I saw some implicit methods for prolongation. I was wondering if I should put the effort in doing that.
3) In the coarse grids can I have a first order approximation for convective fluxes and second order for viscous fluxes? I guess it would be more stable that way, and permit a relaxes time stepping in coarser grids.
4) Is there explicit algebraic multigrid technique for finite volume methods (without forming a big matrix). If so, can you give a reference?
Thanks in advance for your clarifications.
Shyam
LES by Multigrid mnabi Main CFD Forum 8 July 11, 2009 20:21
multigrid sureshkumar Main CFD Forum 0 June 9, 2006 01:20
local timestep for agglomeration multigrid method Jian Xia Main CFD Forum 3 March 20, 2000 11:20
Agglomeration multigrid to solve Euler equations Jian Xia Main CFD Forum 3 January 11, 2000 18:07
Multigrid applied to k-e models Paulo Zandonade Main CFD Forum 9 May 24, 1999 08:10
