Does it metter to increase RAM for solver speed??
Old   February 28, 2008, 06:18
Default Does it metter to increase RAM for solver speed??
raima
Hi, I was initially running a solver on 4 GB linux m/c. My runtime was around 7.5 days. I increased RAM till 8 GB, but runtime has reduced only by half day. I need to ask, wher did I lack??? Does it metter to increase RAM for solver speed?? Is it also depending on mesh quality??? My mesh quality is gud.
regards raima.
Old   February 28, 2008, 10:47
Default Re: Does it metter to increase RAM for solver spee
TG
If you have a 32bit OS or machine, then increasing the RAM beyond 4GB does nothing. If you have a 64bit OS and 64bit machine then you can increase the RAM beyond 4GB. If the problem takes more memory than available, then the machine will swap and run slow. Increasing the memory will speed up the machine until you have enough so that it no longer swaps. Once it stops swapping, increasing the memory further will have no effect. If you run the "top" command you ought to be able to see how much real memory is used vs how much virtual (ie swap space) and how much your job requires. Runtime also depends on mesh quality as "good" meshes tend to converge quicker than "bad" ones.
Simulation speed increase Attesz CFX 24 October 13, 2010 09:55
Hard disk speed important to increase CFD computing speed? lawrencelaw Hardware 13 November 17, 2009 14:35
Speed increase with new amd cpu zonexo Main CFD Forum 19 April 14, 2006 12:32
Fluent and RAM Speed Allan Walsh FLUENT 6 April 21, 2004 16:08
How to Increase Speed? steve podleski Main CFD Forum 23 January 11, 2000 15:41
