Best coding and benchmarking practices for Fortran
Like Tree1Likes
  • 1 Post By sbaffini
Old   November 19, 2020, 06:49
Default Best coding and benchmarking practices for Fortran
Sayan Bhattacharjee
aerosayan is on a distinguished road
What are the best coding and benchmarking practices for Fortran?
I was surprised to see that x(i) = x(i)**4 was WAAAAAYYYYYY faster than x(i) = x(i)**4.0
It was quite surprising to see this. I thought the compiler would understand how to optimize the code since the compiler has access to the constant term 4.0. The compiler could have simply converted 4.0 to 4. But for some reason it didn't.
Kindly share some things you know.
Thanks
Here's my benchmark code and compiler flags:
! COMPILE : gfortran -g -O3 -mavx2  power.F90
! DISASM  : objdump -d -SC -Mintel  a.out
program main
implicit none
integer *4 :: n, r, rmax
real       :: time_start, time_end
n = 8**8
rmax = 10
print *, "N            : ", n
print *, "REPITIONS    : ", rmax
print *, "--------------------------------------------"
print *, "BENCHMARK x(i) = x(i)**4"
print *, ""
do r=1,rmax
    call cpu_time(time_start)
    call power_integer(n)
    call cpu_time(time_end)
    print *, " - TIME ELAPSED      ", time_end - time_start
end do
print *, "BENCHMARK x(i) = x(i)**4.0"
print *, ""
do r=1,rmax
    call power_real(n)
end do
contains
subroutine power_integer(n)
implicit none
real    *4 , dimension(:), allocatable :: x
integer *4 :: n, i
allocate(x(n))
do i=1,AND(n,-8)
    x(i) = 2.0
end do
do i=1,AND(n,-8)
    x(i) = x(i)**4
end do
deallocate(x)
end subroutine
subroutine power_real(n)
implicit none
integer *4 :: n, i
allocate(x(n))
do i=1,AND(n,-8)
    x(i) = 2.0
end do
do i=1,AND(n,-8)
    x(i) = x(i)**4.0
end do
deallocate(x)
end subroutine
end program
Here's my result :
 N            :     16777216
 REPITIONS    :           10
  - TIME ELAPSED        0.105583996
  - TIME ELAPSED         6.43480048E-02
  - TIME ELAPSED         4.91680056E-02
  - TIME ELAPSED         4.82190102E-02
  - TIME ELAPSED         4.89619970E-02
  - TIME ELAPSED         4.88489866E-02
  - TIME ELAPSED         4.95190024E-02
  - TIME ELAPSED         4.94549870E-02
  - TIME ELAPSED         4.96839881E-02
  - TIME ELAPSED         4.93779778E-02
  - TIME ELAPSED        0.121948004
  - TIME ELAPSED        0.121810973
  - TIME ELAPSED        0.121183991
  - TIME ELAPSED        0.120921016
  - TIME ELAPSED        0.120067954
  - TIME ELAPSED        0.121345043
  - TIME ELAPSED        0.120756984
  - TIME ELAPSED        0.120249987
  - TIME ELAPSED        0.120095015
  - TIME ELAPSED        0.120734930
aerosayan is offline   Reply With Quote
Old   November 19, 2020, 09:14
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
The general reasoning is that you are in charge of stuff. Should the compiler analyze every occurrence of reals in your code to understand what you actually want to do? Intel would probably do it (see here https://community.intel.com/t5/Intel...on/td-p/924287), but your mileage with other compilers might vary. So it is certainly a good practice to use integers in this case and whenever the result is translatable to a very different operation. Here integer exponentiation is just multiplication. But this might actually be an extreme case.
Tricks really depend from what you know or don't. Also, most things in Fortran are, purpotedly, not standardized. For example, do you know that, despite the work by reference, most compilers (probably all of them) will likely do a copy of your input to a subroutine if it is a non-conitguous stride of a larger array? Which means that, sometimes, it is just better to pass the whole thing and indexing in the subroutine, if that makes sense.
aerosayan likes this.
sbaffini is offline   Reply With Quote
benchmarking, fortran code
