-   Main CFD Forum (https://www.cfd-online.com/Forums/main/)
-   -   Solid EOS (https://www.cfd-online.com/Forums/main/14938-solid-eos.html)
adam March 16, 2008 14:55
Solid EOS
Hi
I need EOS for a Solid phase. Can some one introduce an EOS in the form:
P = ?????
i.e. an EOS similar to the ideal gas. Am modeling a mixture of gas-solid two-phase flow, 1-D.
Thank you for your help and guidance.
jinwon park March 17, 2008 16:42
Re: Solid EOS
See the stiffened gas EOS. This provides parameters for various media which are solid, liquid and gas. Good luck.
Jinwon
jinwon park March 17, 2008 16:47
Re: Solid EOS
Or you can also see the Gruneisen EOS. The stiffened gas EOS is a reduced form of the Gruneisen EOS.
adam March 18, 2008 02:57
Re: Solid EOS
i have looked to Gruneisen EOS but i couldn't derive a formula for:
P = .........
can we use the ideal gas EOS for a solid? i.e. P = k \rho^{gamma -1}
Thanks
jinwon park March 18, 2008 07:06
Re: Solid EOS
The stiffened gas EOS is able to be recast as it.
adam March 18, 2008 13:12
Re: Solid EOS
Many thanks for your reply. I hope you, or any one out there, will help me about the following. The EOS is:
e_{k} = \frac{P_{k} + \gamma_{k} P_{0}}{\rho_{k} (\gamma_{k} - 1)} where k = g (gas), s (solid)
* For the GAS phase I have taken:
P_{g} = K_{g} \rho_{g}^{(\gamma_{g} - 1)}
with P_{0} = 0
** what shall I use for the solid phase.
P_{s} = what............. ?
Am doing mathematical analysis for a compressible mixture of gas-solid two-phase flow in 1-D only.
