Wall fonction
Old   November 3, 1999, 06:18
Default Wall fonction
chaker
Hi..
I work with turbulent natural convection flow of air in the square cavity with differentially heated vertical side walls. I use the following wall fonction for turbulent variables: K=0. at the wall Epsilon=Cte (K^(3/2))/l at the first inner grid point with l the closest distance to wall
I use Cte=0.4 is it true??? or may I use an other value???
Thanks for your help
Old   November 3, 1999, 09:44
Default Re: Wall fonction
Valdemir G. Ferreira
The constants in K-epsilon model are not the same for all flows.I suggest you look for relacted flows in square cavities.
Valdemir.
Old   November 4, 1999, 04:45
Default QUICK or CUI is third order?
Grigory
Hi, I consider well known van Leer class of the k-scheme: phi_f=phi_C+(1/4){(1+k)(phi_D - phi_C)+(1-k)(phi_C-phi_U)}. In many papers it is written that setting k = 1/3 we receive the scheme of the 3-rd order (so-called CUI scheme), but I receive the 3-rd order only at k = 1/2 (i.e. QUICK-scheme). Where can be an error? Grigory.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
