March 9, 2015, 17:46 |
Why is transitional Re is >> 1
Recently one person asked me why transitional (laminar to turbulent) Reynolds numbers are big (10^3 to 10^5) while all coefficients in Navier-Stokes equation are of order of 1?
The person is not an expert in fluid mechanics and asked for a reasonably simpe explanation. Is there one? Truffaldino |
March 10, 2015, 03:31 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Hello, I can not focus on the meaning of this question.... The Re number depends on the choice of the velocity and lenght, therefore is not a unique definition...for example in channel flows you can have a fully developed turbulence at very low Re(_tau) number. On a flat plate you have flow increasing Re_x number. A laminar Poiseulle solution is valid for any high Re number, the problem is that physically it is not stable for high Re. The answer is more related to a stability analysis (linear and non linear) rahter than to the coefficients of the equations... |
March 10, 2015, 07:39 |
To me this question looks quite reasonable.
Imagine a person who takes a look at NS equation for the first time: This is an equation where all coefficients are 1 and it has one parameter nu which is nu=Re^-1 in the front of Laplacian. All the length and speeds in this system of scales are order of 1. Then person finds out that the transition happens when the parameter is almost zero nu=10^-3, 10^-5. Equation itself does not contain Re_theta and other things obtained in process of its solution. So, the person must suspect that there is a simple and fundamental reason why does transition happen when this parameter is almost zero. |
March 10, 2015, 08:05 |
#4 | |
Rep Power: 71 |
if you consider the fact that the for very small viscosity the NS equations are actually perturbed non-linear equation, it is well known the fact that the solution for hyperbolic non-linear equations can be not-unique. Transition is just a bifurcation of the solution when you get conditions when the non-linear convective parte is more relavant than the diffusive linear part. The Re number is someway the parameter that guides small perturbation to be suppressed by the diffusive effects or to be amplified by the non-linear convective effects. |
March 10, 2015, 08:44 |
#5 | |
And another question: why does diffusive part become more relevant than convective at such a small parameter? |
March 10, 2015, 09:08 |
Rep Power: 71 |
O(1) Div (vv) + O(1) Grad p and as counterpart O(1/Re) Lap v so that for Re>>1 you can see the perturbed Euler equation
March 10, 2015, 11:17 |
#8 | |
Rep Power: 71 |
Again, analysing critical values for the Re number is a topic of the stability analysis and depends on the type of flow. The answer is not simple... Basic tools for the stability can be found in classical fluid mechanics books but many issues are still open questions and you can find many papers published in scientific journals such as JFM, PoF, etc |
March 10, 2015, 16:52 |
#9 |
I was asking this question since friend of mine, who is not a specialist in fluid mechanics, sent me a note written by his former supervisor who is a specialist in quantum field theory (qft). Using qft techniques he somehow shows that critical Re must be high, and his demonstration is quite general (i.e. suitable, in principle, for any flow).
To me use of qft technique for such a purpose looks quite excessive and I thought that there must exist much simpler explanation. From cfd literature I red I remember that people uses long analysis (eg orr-sommerfeld etc) and it is not universal. But I have never seen any simple general explanation. |
March 10, 2015, 18:02 |
#10 |
Rep Power: 71 |
This aspect is very complex and can not be determined by a general observation of the Re number.
I suggest a reading of Chap. 11 of Kundu. |
March 15, 2015, 12:25 |
#11 |
Martin Hegedus
Rep Power: 19 |
To some extent, one can view the transitional Re as a multiple of the characteristic length of a vortex. I guess. I'm just making this up. In other words, it takes lots of vortiticy for transition to occur.
March 15, 2015, 12:30 |
#12 |
Martin Hegedus
Rep Power: 19 |
Or, another way to look at this. The length value that is chosen for the Re is sort of arbitrary. So, if one chooses a length such that Re=1, what does that length represent?
March 15, 2015, 14:21 |
#13 |
The idea to use vortex sizes and dimensional considerations to explain (qualitatively) big values of critical Re seems to be reasonable.
March 15, 2015, 15:05 |
#14 |
Here is an idea: why not to estimate the total time of decay of biggest eddies through the cascade till the Kolmogorov scale and then multiply this time by freestream velocity: This will give the qualitative estimate of the transition length and the transition Re.
March 16, 2015, 07:58 |
#15 | |
Rep Power: 71 |
The free-stream velocity, the lenght of biggest eddy define the globa Re number... |
March 16, 2015, 09:08 |
#16 |
Ok, this is a wrong idea, but why can't we show that critical Re should be big (not to find it, but just demonstrate that it is big) in Kolmogorov's style.
Say, to estimate order of total dissipated energy and find order of Re when it is possible, or some other very rough considerations. |
March 16, 2015, 09:41 |
#17 |
Martin Hegedus
Rep Power: 19 |
Warning, I know very little about this, but I did some googling and found the Orr-Sommerfeld equations.
http://en.wikipedia.org/wiki/Orr%E2%...rfeld_equation |
March 16, 2015, 09:49 |
#18 |
Martin Hegedus
Rep Power: 19 |
March 16, 2015, 10:05 |
#19 |
Martin Hegedus
Rep Power: 19 |
OK, I gather Orr-Sommerfeld has already been brought up on this site.
March 16, 2015, 10:18 |
#20 |
Yes Orr-Sommerfeld is a very well-known stability analysys based on linearization. It is aimed to find value of critical Re.
But the question is not finding Re, but just to qualitatively demonstrate that it should be big, without solving NS equation, just by some general consideration in Kolmogorov's style. Say, e.g. to estimate order of total dissipated energy and find order of Re when it is possible, or some other very rough considerations. |
Difference between Fluent transitional model and CFX transitional model | Anna Tian | FLUENT | 2 | August 7, 2014 10:52 |
LES transitional pipe entrance flow | hasanduz | Main CFD Forum | 2 | October 11, 2013 17:59 |
Question about transitional model | Anna Tian | CFX | 3 | March 4, 2013 16:45 |
Should I use the transitional turbulence? | hopehope | CFX | 1 | November 14, 2012 16:47 |
Questions about Y+ and Transitional Flows | Justin Figley | FLUENT | 4 | March 5, 2008 17:25 |
