Flotherm vs. Fluent
Old   March 24, 2008, 18:58
Default Flotherm vs. Fluent
Boris
Our company is going to invest some money in CFD software for electronic packaging development on card and box level. Two candidates are Flotherm from Flomerics and Fluent from ANSYS. Are there any comparison charts that make selection easier?
Thank you, Boris Levin, ME SolidWorks 2008
Old   March 24, 2008, 23:31
Default Re: Flotherm vs. Fluent
Ahmed
I guess you mean Icepak from Fluent (Ansys), you cannot compare the Fluent 3D solver to a specialised programme like flotherm. These special programmes solve the incompressible Navier Stokes equations (air speeds are less than Mach 0.3, so there is no need to solve for the compressibilty effects) so you have to ask your electronics card designer what file format his design software produces and then see which product reads these file format. In the end you will select the product that fits your budget, the one that you feel comfortable working with, but most importantly the one with support engineers that speak your language. Good Luck
Old   March 25, 2008, 09:53
Boris
Ahmed, Thank you, you are right. I meant Icepack from Fluent vs. Flotherm. I am sure there are people who went tru this selection process and might advice something. Or, may be, some people are familiar with both tools and can help. I just don't want to rely on luck.
Old   March 26, 2008, 14:14
Default Re: Flotherm vs. Icepak vs. Coolit
Ahmed
Let me add to your list another player, Coolit http://www.daat.com/Coolitjump.php?P...4baf9ca927b17a Without knowing exactly what type of analysis you are planning to do with this software, it is difficult to give any serious recommendation, the three solve the same set of equations using the same discretization methods, etc.......... You can ask for a trial license and check by yourself what is there or, and if you can, give one of your problems to their support engineers and compare the results obtained. I have used Icepak not only to solve thermal management problems for electronic systems but also to solve other fluid mechanics problems that did not require the compressibilty effects to be included. Selecting a software is a technical decision, luck has nothing to do with it
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
FLUENT and FLOTHERM Q. Diao Main CFD Forum 1 July 8, 1998 14:46
