March 12, 2015, 13:29 |
k-e, RNG or K-w
Adam
Rep Power: 11 |
I cant decide which type of turbulence model I should be using. what do you think would most accurately model high speed flow separation off a flat plate, but could reasonably predict the mixing with the free stream of air above it?
March 12, 2015, 14:41 |
Matt
Rep Power: 17 |
RNG is just a special form of k-e that tries to approximate all turbulent length scales rather than just one (as with k-e). RNG is probably a little more applicable than just a standard k-e approach. However, k-w tends to do a little better with pressure gradients (which are what drive separation).
That being said, if accurately modeling the flow separation is your goal you probably need to use a DNS approach, not RANS (maybe you can get away with LES). Of course, the term accurate is highly subjective. Most people can justify a RANS analysis with 2-equation model. |
March 14, 2015, 13:41 |
Hamid Zoka
Rep Power: 18 |
I think you can get better results if you use low-Re turbulence models like SST-K Omega. High-Re turbulence models like standard k-epsilon generally gives poor prediction of separated flows.
March 18, 2015, 11:59 |
Engineer B
Rep Power: 11 |
Hi. can every one help?
I want to simulate weir using ansys cfx code and i used RNG turbulence model. but the results are not good and i can not get the ventilation region in water profile. Last edited by bshkoj; March 20, 2015 at 02:31. |
flow seperation |
RNG k-epsilon model implementation | romant | OpenFOAM Running, Solving & CFD | 2 | June 20, 2018 08:33 |
why RNG k-e is better & what does RNG really mean? | Bonnie White | FLUENT | 1 | August 8, 2006 09:14 |
HELP!! Prandtl numbers in RNG k-e turbulence model | maoasis | FLUENT | 0 | April 24, 2006 10:51 |
RNG k-e equation | Mahshid | Fidelity CFD | 0 | October 24, 2005 09:51 |
RNG with Schemit number | zwdi | FLUENT | 0 | August 2, 2004 11:54 |
