MAKING A WIND TUNNEL
Old   March 31, 2008, 08:36
Default MAKING A WIND TUNNEL
Shriram
i need to make a wind tunnel of plywood for testing a plate fin heat exchanger . the exhaust from the engine is fed through the Wind tunnel and then to the heat exchanger. the heat exchanger of of 60 com in length and fins of 15*15 are welded over it.the temperature of exhaust is around 500'c.
The diagram of the entire process is given in this link. It a 2MB image file.
Please help me on making the wind tunnel.
Thank You http://rapidshare.com/files/10377812...unnel.bmp.html
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
flow in cyclic wind tunnel yogesh@cfd Main CFD Forum 0 November 8, 2010 04:28
how to consider perforated wind tunnel wall in CFD simulation littlelz CFX 4 June 11, 2009 05:51
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
