May 9, 2015, 11:01 |
LES and Symmetry?
John
Rep Power: 11 |
I am simulating detached flow over a wing using LES. I was wondering if it is common to use a symmetry plane to reduce the computational cost by a factor of two (only simulating one side of the wing). I know that the symmetry condition will not be physically accurate at the symmetry plane for LES.
However, it may be "close enough". Is this done ever in practice, or is LES always computed on a full geometry (without a symmetry plane). I've attached an image of my simulation with the symmetry plane. Notice the non-physical vortical structures at the mid-plane. Thank you, John |
May 9, 2015, 11:16 |
Filippo Maria Denaro
Rep Power: 71 |
if you are interested on all the physical aspects over the wing you cannot use symmetry conditions
Problems of bad results with LES | Sunxing | OpenFOAM | 10 | March 31, 2014 05:11 |
Spanwise Length and Grid Refinement for SAS-SST, DES, and LES | Josh | CFX | 5 | October 14, 2010 19:47 |
Symmetry plane for LES in channel | Flo | Main CFD Forum | 3 | March 12, 2009 11:40 |
Symmetry model half or total geometrical model in LES | vvqf | OpenFOAM Pre-Processing | 3 | March 22, 2006 09:06 |
use of common RANS B.C.'s in LES? | Sanjin Saric | Main CFD Forum | 0 | March 21, 2002 06:08 |
