April 8, 2008, 04:22 |
Faceted surfaces in ICEM
I have some short questions about ICEM 11 and its unstructured tetra mesh generation. Because I have to combine some surfaces, ICEM creates these Faceted Surfaces. Might it be a problem for the mesh generation using this kind of surface instead of B-spline surfaces? Can a following calculation (with Fluent) be influenced by these surfaces? What is the difference between both kinds of surfaces? Thanks for your help, Chriss |
May 6, 2008, 15:18 |
Re: Faceted surfaces in ICEM
I don't know anything about ICEM 11, but I do know that meshing faceted geometry can lead to problems. Using faceted geometry to represent high curvature regions (such as airfoil leading edges) can cause flat spots, i.e., the mesh doesn't lie on the true geometry, invalidating your flow calculation. This is not usually a problem if the mesh tool evaluates a B-spline surface directly.
For more details try: Pros and cons of various geometry exchange formats |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
[ICEM] Difficulty creating surfaces in ICEM | johnp | ANSYS Meshing & Geometry | 7 | May 14, 2013 04:22 |
Periodic cut surfaces - ICEM? | Jane | CFX | 0 | May 18, 2008 20:55 |
Design Modeler to ICEM..... | Joe | CFX | 0 | January 24, 2008 03:39 |
Surfaces lost from ICEM to CFX-Pre 5.7 | Mark | CFX | 6 | September 30, 2004 23:07 |
