Efficiency for hovering flight?
Old   April 13, 2008, 11:14
Default Efficiency for hovering flight?
Zonexo
The definition for propulsive efficiency is thrust * velocity / power input. This formula works for fixed wing as well as flapping wing.
So what if the plane or aircraft is hovering? How do you define its efficiency? Or what type of efficiency can be defined? Is it hovering efficiency?
Lastly, is the formula applicable to both helicopters n flapping MAV?
thanks
Old   April 14, 2008, 00:49
Default Re: Efficiency for hovering flight?
sudhakar
Hi Zonexo, During hovering flight, the efficiency = (avg. Lift/avg Drag). For a hovering flight, it is obvious that avg drag=0. So we must take avg drag over one half stroke. It must be pointed out that this definition is applicable only for flapping on a horizontal stroke plane.
initial and boundary conditions for flapping hovering flight quarkz Main CFD Forum 4 August 30, 2012 13:11
Efficiency, thrust/drag with regard to hovering quarkz Main CFD Forum 0 April 21, 2010 00:51
Droplet Collision Efficiency Calculation using DPM Virk FLUENT 0 January 22, 2010 09:37
The calculation efficiency of OpenFOAM chiven OpenFOAM Running, Solving & CFD 4 September 14, 2009 04:44
Parelleling Efficiency kassiotis OpenFOAM 0 June 19, 2009 14:12
