Home > Forums > Software User Forums > Phoenics
Phoenics
Old   March 27, 2015, 21:13
Default Phoenics
Khurram Gohar
Khurram381 is on a distinguished road
Does any one know how i can calculate the Drag coefficient from total force in phoenics CFD of my 3 blade horizontal axis wind turbine ? When i'm trying to calculate from the output tab in domain settings, it is asking me to give the Reference area in X, Y and Z.
I'm a bit confused about calculating area along X,Y and Z axis. can any one help me on how i can find the area ?
Blade length is 3 meter
total surface area is 5.86 square meters
No of blades 3
rotor area is 0.73 square meter.
would be grateful if you can also tel me how the power can be measured?
I'm using NACA 4412 airfoil.
Khurram381 is offline   Reply With Quote
Old   March 27, 2015, 21:29
Khurram Gohar
If any one wants my model of turbine , i can send the solid works file for his/her simulation (through email). furthermore even if anyone can tell me how can i find the areas along x, y and z-axis of attached blade , than i would be grateful. I also would like to know how can the lift be calculated in phoenics.
thanks
Old   October 11, 2018, 11:14
Anastasios Dalas
Anastasis is on a distinguished road
No of blades 3
I have the same problem about calculating lift on NACA 4412, can anyone help?
Anastasis is offline   Reply With Quote
Old   February 13, 2020, 11:27
CHAM Support is on a distinguished road
Please see the below for a link to information on the force-summation output and the drag-coefficient calculation:
http://www.cham.co.uk/phoenics/d_pol...20on%20Objects
You are looking for this formula here, which calculates the drag coefficient:
Cd_i = F_i/(0.5*RHO_ref*Vel_ref*Area_(ref,i))
You have your reference area, and I will assume you have a reference velocity and density too. From this, if you have included only the rotor elements in the force summation, this will give you a drag coefficient in the spreadsheet, which is output during the run.
You can calculate the moments by inputting the coordinate which you would like your moments to be taken around in the final 3 boxes of that menu.
There are lots of informative tutorials about PHOENICS here:
http://www.cham.co.uk/phoenics_tuts.php
There is also a lot of documentation here:
http://www.cham.co.uk/documentation.php
http://www.cham.co.uk/phoenics/d_pol...c/encindex.htm
Thanks,
Harry
CHAM Support is offline   Reply With Quote
ICEM CFD (Hexa) - > Phoenics James Date Phoenics 2 September 2, 2004 16:18
transonic calculation yann Phoenics 3 May 20, 2003 11:35
Colors & DXF format in Phoenics. HELP Yiannis Phoenics 3 November 12, 2001 14:00
PHOENICS code IV mehdi Main CFD Forum 3 July 7, 2000 19:49
Use of an hydrodynamic model integrated in the vertical by the PHOENICS code Hafsia Zouhaier Main CFD Forum 2 March 15, 1999 09:23
