Error #004100018
hello everyone,
I am working on air and water mixture analysis. but while simulation it is showing me error: ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver I don't know whats the problem, but while simulation it is showing some notice: | ****** Notice ****** | | The Wall Heat Transfer Coefficient written to the results file for | | phase: air | | on domain: fluid5 | | is based on the turbulent wall function coefficient. It is | | consistent with the Wall Heat Flux, the wall temperature, and the | | Wall Adjacent Temperature (near-wall temperature). If you would | | like it to be based on a user-specified bulk temperature instead, | | please set the expert parameter "tbulk for htc = <value>". | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | The Wall Heat Transfer Coefficient written to the results file for | | phase: water vapour | | on domain: fluid6 | | is based on the turbulent wall function coefficient. It is | | consistent with the Wall Heat Flux, the wall temperature, and the | | Wall Adjacent Temperature (near-wall temperature). If you would | | like it to be based on a user-specified bulk temperature instead, | | please set the expert parameter "tbulk for htc = <value>". | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | The Wall Heat Transfer Coefficient written to the results file for | | phase: water | | on domain: fluid6 | | is based on the turbulent wall function coefficient. It is | | consistent with the Wall Heat Flux, the wall temperature, and the | | Wall Adjacent Temperature (near-wall temperature). If you would | | like it to be based on a user-specified bulk temperature instead, | | please set the expert parameter "tbulk for htc = <value>". Is there any relation between this notice and the error??? as i am having the multiphase problem, so i defined the heat transfer for air and water mixture. I think this notice is because of that only... Do anyone have idea about this?? please help me for that... Thanks in advance/.....:) |
I can't answer this, but if you wish others to help, you should specify at least what software you use.
:p Oooops sorry Rami, I forgot to mention the software...
Anyways i am using CFX 15.0 for the analysis... |
