March 31, 2015, 15:54 |
Boundary conditions
Rep Power: 11 |
Hello everyone,
My project needs 4 co sources every source has flow rate 0.6 L/min. Which TYPE in boundary conditions should i choose in this case ????? I tried to choose mass-flow inlet but its unit in kg/s. Any help or note to give |
March 31, 2015, 17:01 |
Matt
Rep Power: 17 |
It is an arbitrary exercise to convert from volume flow rate (L/min) to mass flow rate (kg/s).
Mass Flow = Density * Volume Flow. Just make sure that you convert your volume flow rate into m^3/sec and specify density as kg/m^3. That of course assumes that you know either density or pressure and temperature of the incoming fluid. If not, your problem is under-defined. |
Matt
Rep Power: 17 |
I guess I should have asked, does CO mean carbon-monoxide?
March 31, 2015, 22:59 |
Rep Power: 11 |
Yes its carbon-monoxide.
Thank u so much |
March 31, 2015, 23:02 |
Rep Power: 11 |
What if i have 4 cylinders every cylinder gives 75 watt for example which type should i choose???
April 1, 2015, 08:17 |
Radwanma
Rep Power: 11 |
Hi all,
I have this problem in FLUENT : WARNING: Limited wall distance for 241 cells to 1.000000e-12. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. Do you know the reasons of this problem?!!!! |
April 1, 2015, 10:39 |
Matt
Rep Power: 17 |
Radwama: It sounds like you have issues with your cells being to close to the wall. You should really post this in the Fluent formum...
Ali: Are you trying to apply this to your mass flow inlet or a wall near the mass flow inlet? I am a little confused. |
April 1, 2015, 16:23 |
Rep Power: 11 |
Haha i am sorry look i am working on small project consist of:
-room (2.5*2.5*3 m).wall temp 28 kalvin. -4 cylinders of diameter 0.3 m each one at temp 34 kalvin and gives 75 watt and they are symmetric to each other in this room. -4 co source placed at top of cylinders each source gives 0.6 L/min. -air supply (1.5*0.2m) gives 1.5 kg/s at temp 28 kalvin. -exhaust (0.6*0.6m). So which type should i choose for cylinders? |
April 1, 2015, 16:37 |
#9 |
Matt
Rep Power: 17 |
That really depends on your software package. However, you can probably specify a wall boundary condition with a heat flux component. (w/m^2).
April 1, 2015, 17:43 |
#10 |
Rep Power: 11 |
Thank uuuuuuu
Display Modes | |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
