Through-Flow solver, Leading-Trailing edge problem
Old   May 14, 2008, 18:14
Default Through-Flow solver, Leading-Trailing edge problem
Menander
Hello there, being a couple of years a PhD student in Athens, Greece, I am now confronting a problem concerning the convergence ability of a through-flow solver for axial compressors. It's of time-marching type, solving the peripherally averaged equations of conservation of mass (1), momentum (3) and energy (1), in their inviscid form. It uses the common McCormack method. I think that the code doesn't manage to converge satisfactorily, even after 5000 iterations. Can somebody tell me why? I suspect that the "abrupt passage" of the flow from the free inlet space to the blading, via the Leading Edge, as from The Trailing Edge to the outlet free space could be the reason. I would sincerelly thank the person who will try to enlighten me and suggest me a way of solution.
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 11:34
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 10:42
Problem with implicit unsteady solver CCMuser STAR-CCM+ 2 March 3, 2010 11:20
Nonphysical flow field while using coodles solver ankgupta8um OpenFOAM Running, Solving & CFD 5 January 26, 2008 16:54
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 16:52
