FTCS Error Residuals
Old   April 4, 2015, 15:34
Default FTCS Error Residuals
anonymous
anonymousbach is on a distinguished road
Hi All,
I am trying to solve a 2D transient heat problem using a FTCS Finite Difference, Explicit Scheme. The system is rectangular domain, with constant 0 deg C on the longer (side) walls and two different, positive temperatures at the top and bottom (also constant). Now, my code converges to the desired criteria, the values seem reasonable.
Overall, my average %error compared to an exact solution is around 7.2%, but in one corner the error peaks at about 70% and along one wall, it averages around 50%. Hopefully you can see the image I've attached to give a clearer picture.
What makes me worries is these errors seem unaffected by timestep. Are errors like this common in using FTCS schemes with a fairly coarse grid? Can anyone think of any reason why I'm having these unusual errors?
As always, any help would be greatly appreciated.
anonymousbach is offline   Reply With Quote
Old   April 4, 2015, 17:17
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
1) what about the exact solution you used?
2) in the errors plot, are you visualizing only the inner nodes?
3) the errors are computed at the steady state?
FMDenaro is offline   Reply With Quote
Using FTCS to solve a reduced form of Navier-Stokes eqn DA6righthand Main CFD Forum 8 April 2, 2015 04:14
