compressible flow algorithm
Dear friends: I have treated the incompressible flow for several years, by using the famous algorithm of Pantakar, simple alogirthm. Now, i want to have some knowledge in the compressible flow expecially the supersonic compressble flow used in the aerodynamic fields. Would you please give me some good references for a start about the solution algorith for the compressble supersonic flow. Regards
Re: compressible flow algorithm
People have extended the simple algorithm for compressible flows. You might want to look into that unless you are more interested in developing a density-based scheme.
thank you very much, woudl you please give me some good references for the density-based schmeme regards
The CFD book by anderson, pletcher and tanheill discuss the implementation of maccormack and beam-warming schemes for density-based solvers. For finite volume implementation you might want to check Blazek.
-H |
Thank you very much Harish, i am so sorry to bother you again, would you please tell me the name of book by these people. regards
