Boundary conditions
Old   May 10, 2008, 23:31
Default Boundary conditions
shuo
When pproximating derivatives at boundaries should the finite differencing be of at least the same order of accuracy as those used in interior points?
Shuo
Old   May 12, 2008, 06:32
Default Re: Boundary conditions
InddZen
Hi You don't have to... Most papers uses first or second order approx. at the boundaries, but if you can do it, meaning use the same order, so it's of course better, specially if you're developping a high-order scheme.
It's also important to keep in mind the type of error (dipersive or dissipative), so somethimes it's better to use an inferiror order because its error is dissipative.
Hope it helps
Old   May 12, 2008, 12:52
Harish
The most important issue to be thought over is the stability of your system when using the same order of approximation which might involve a wider stencil. There is a paper by Carpenter(I do not remember the name ?) which discusses this issue in detail. There are many numerical schemes which use the same order of accuracy at the boundary/interior.
Thread Tools
Trackbacks are On
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 05:37
boundary conditions and mesh exporting vaina74 Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 May 27, 2010 09:38
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
