Export CFD Solver results to text file format
Old   May 22, 2008, 19:17
Default Export CFD Solver results to text file format
Maik
I'm a computer graphics student and did some CFD simulations at the university lab with a software called UGS NX5. I used the Advanced Simulation Environment and did a Flow simulation for external air flow around an obstacle.
Everything works fine so far, but I'm a bit lost about exporting functionality. As my purpose is to visualize the results myself, I need to be able to read the solver's results. Does NX5 allow such an operation?
Ideally, I would get an .XML or .VRML file containing the results.
Can you help me out? I assume that portability of such data is not intended by the software manufacturer, however I'm sure I'm not the first person trying such a thing.
I'd love to hear hints or even recommendations about other CFD software that writes into open file formats.
Regards Maik
Old   May 22, 2008, 19:39
Default Re: Export CFD Solver results to text file format
otd
I'm not familiar with the CAD software market. I did check the website and found a pretty drastic warning about 'piracy'. Since you're in a university, the university should have a license and - support from the company who sells the software.
Have you asked the company how to get the output you need?
Old   May 23, 2008, 01:34
Maik
no I haven't asked them, but that's a good idea. I'm going to do that. Thanks
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
