Help: Serial code to parallel but even slower |
April 13, 2008, 04:51 |
I've a serial 2D CFD code. As my grid size requirement increases, the simulation takes longer. Also, memory requirement becomes a problem. Grid size 've reached 1200x1200. Going higher is not possible due to memory problem. Currently, I'm using the PETSc solver which is a parallel MPI solver, to solve the momentum and poisson eqn. I tried to convert my code to a parallel one but after restructuring and enabling the parallel mode of the solver, I found that it is much slower, although the answer is correct. I wonder what I should do to check what's wrong. Btw, is a grid size of 1200x1200 suitable for parallel run of 4 processors? I read that if grid is too small, it may be inefficient. Thank you. |
April 13, 2008, 10:08 |
Re: Help: Serial code to parallel but even slower
From my experience a small problem like yours won't scale very nice on multiple machines because the communications will take longer than the calculations. Try to run the same problem on a dual/quad core machine and if your code is correct it will run faster.
April 13, 2008, 10:47 |
From my experience, I dont think 1200 x 1200 ( ~ 1.4 Million Unknowns ) is a small problem. You should get a speedup. Try timing the Poisson equation part only and see if you get a speed up.. -Dominic
April 14, 2008, 03:38 |
Which mpi implementation are you using ? If you have access to different mpi like mpich, mpich2, openmpi, lammpi, then try compiling with others and check. In our experience, we found mpich2 to give poor performace which was dramatically improved when we used openmpi.
May 14, 2008, 10:26 |
Have you tried OpenMP? This is an easier option i.e less work involved. You could try automatic parallelization as a first step.
As for the MPI code, there are tools available such as vampir and jumpshot to analyze the code and see why it is slow. |
Display Modes | |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
Self implemented code is not running in parallel | michi | OpenFOAM Running, Solving & CFD | 2 | November 6, 2008 05:09 |
Parallel convergence worse than serial! | Michael B | FLUENT | 3 | December 9, 2006 21:46 |
Problems with MFIX code and Parallel Processing. | Fernando Pio | Main CFD Forum | 4 | August 29, 2006 14:33 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
