April 12, 2000, 23:34 |
Need help with 1st order FV scheme
Hi, everybody!
I have written rather basic first-order compressible unsteady 2D Euler FVM for triangular unstructured mesh. My FV scheme is quite clear - piecewise constant reconstruction, Roe_FVS/Godunov fluxes evaluation, one-step evolution, it is well debugged, and works quite correct - except the region behind the 135 degree corner - in the cell right behind the corner point, ajacent to wall, velocity speeds up to hypersonic values, with its vector remaining parallel to wall. So the h/sonic 'spot' is formed and the solver terminates. This occurs at reasonable, but subsonic Mach number in 'far-field', and in entire range of Courant numbers (<1). I am convinced that it is not mesh- or solver-dependent fault. I also think that this problem must be familiar to those who is comfortable in FVM world to which I am new. So could anybody here explain to me this phenomenon? Thanks in advance, Andrei |
March 14, 2013, 03:37 |
Van leer second order and AUSM+
kian
Rep Power: 13 |
Hi, I've got a fortran code for solving 2D compressible flow over an airfoil with the method of first order van leer flux vector splitting . I have to change it to second order van leer flux vector splitting method . Can you please help me on how to do it? It's also possible for me to solve this project with the method of AUSM+ . Are you familiar with this method? can you help me with it please?
Thanks a lot in advance |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 12:29 |
1st order vs 2nd order | ken | FLUENT | 8 | March 14, 2013 03:43 |
2nd order upwind scheme (Fluent and CFX) | Far | FLUENT | 0 | May 22, 2011 01:50 |
Turbulence quantities solved by 1st order scheme? | Damien | CFX | 3 | May 29, 2007 07:54 |
1st order temporal & 2nd order spatial | Prateep Chatterjee | FLUENT | 0 | January 19, 2003 00:31 |
