May 19, 2008, 16:07 |
boiling heat transfer: h = hL*v^n ??????
Hi!
I found a paper, where the heat transfer coefficient h from a hot surface into an evaporating liquid is expressed with following equation: h = hL*v^n where hL is a heat transfer coefficient that depends on the surface temp and on the state of the liquid, v is the velocity magnitude in the wall nearest cell and n is a constant, n = 0.5 Does ANYONE know, where this equation came from??? For me, it looks like an experimental fit. BUT it of course depends on the cell size, how much of it is inside the BL. Any idea??? Ralf |
May 19, 2008, 18:12 |
Re: boiling heat transfer: h = hL*v^n ??????
It might come from the paper you found it into...or its bibliography
BOILING HEAT TRANSFER COEFFICIENT | John | FLUENT | 1 | September 4, 2013 07:57 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
