How to make a CFD analysis ? (ppt) (I'm using fluent))
Old   May 14, 2015, 15:16
Question How to make a CFD analysis ? (ppt) (I'm using fluent))
Bota Amdrei
andrewmichael is on a distinguished road
Hello guys,
I'm new to the CFD concept. I had studied a elbow (the first tutorial from ANSYS 14.5 pdf) in fluent with different number of the elements for the mesh (50k, 100k, 200k, 400k, 800k of elements).
After I had started to compare the contours of velocity and temperature, velocity and temperature profiles between the meshes. I had the results but I don't know how to put them together, as to choose the mesh with the best properties.
andrewmichael is offline   Reply With Quote
Old   May 14, 2015, 15:46
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
Sounds like what you are doing is a mesh independence check. What you want to do is take your quantity of interest and quantitatively compare it between two mesh adjacent sizes. When the difference is below an acceptable threshold (maybe 5 or 2 percent change depending on what you want) you have found the "best" mesh a compromise between accuracy and resources. Note that even though a solution is grid independent it does not mean it is physically correct. You can achieve grid independence for bad physical models bad boundary conditions etc.
edoan is offline   Reply With Quote
Cfd to ansys thermal to ansys structural interface ssixr ANSYS 17 July 31, 2015 15:18
compiling firefoam Farshad_Noravesh OpenFOAM 27 December 24, 2012 04:21
Fluent CFD vs Fluent CFX gpan FLUENT 0 December 21, 2011 13:09
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
