Is my equation stiff????
Old   June 16, 2008, 05:49
Default Is my equation stiff????
Mehdi Asghari
Hi all;
I want to solve following problem by a numerical method.
In a one-dimentional problem, particle velocity equation for particulated flows is given as follows:
D(Up)/Dt=Fd(Up-U);U =10+x;Up=dx/dt;
That Fd=18mu/ (dp*dp*ro_p*Cc) Cc=1+2l/dp*(1.257+0.4exp-(1.1dp/(2l)) Dp(particle diameter) is equal to 10 (micro meter) and 0.01(micro meter), respectively. Also, mu=0.001003,l=3e-10,ro_p=3900.
I used forth-order Runge-kutta method for solution. dt was suitable for dp=10(micro meter), but required dt for stability in dp=0.01(micro meter) was very small. This dt was so small that solution became impossible. Is his equation stiff? Is there a logical numerical method instead of forth-order runge-kutta method to be solved this problem?
Thanx in advance for any suggestion.
Thread Tools
Trackbacks are On
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 14:01
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Calculation of the Governing Equations Mihail CFX 5 July 25, 2008 17:29
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
