moving mesh
Old   June 26, 2008, 19:04
Default moving mesh
Eugene
Does anyone get some experience in moving mesh?
Old   June 26, 2008, 22:18
Default Re: moving mesh
Vuik
what do you want to know about the moving mesh? Which kind of equations are you solving, and with which kind of grid?
Old   June 26, 2008, 22:23
eugene
I want to study gas flow in a vibration bed. Need to solve N-S equation. All the mesh will be moved up and down in a similar speed. There is no mesh deformation. Can you provide some resource on this area? Thanks
Old   June 27, 2008, 04:30
Vuik
you can use a cartesian grid for your simulation. It is cheaper than curvelinear girds. In cartesian grid, the boundary doesn't fit the cells. There are two known techniques to solve this problem, namely cut-cell, or ghost-cell immersed boundary method. In cut-cell method, the cell will be cut, thus you will have arbitrary shaped cells. In 2D is possible to handel with these arbitrary cells, but in 3D case, I don't advice you to use cut-cell. The geometry of the cells become very complex in 3D. Ghost-cell method is based on forcing the velocity by considering a force term in the momentum equations. This term forces the velocities to be zero on the solid boundaries. They are also applicable for moving boundaries, by applying the interpolation (forcing) on every time step. For cut cell: A CARTESIAN GRID METHOD FOR VISCOUS INCOMPRESSIBLE FLOWS WITH COMPLEX IMMERSED BOUNDARIES , T. Ye1, R. Mittal , AIAA"99"3312
For Ghost-cell: A ghost-cell immersed boundary method for flow in complex geometry, Yu-Heng Tseng *, Joel H. Ferziger Journal of Computational Physics 192 (2003) 593"623
Old   June 27, 2008, 06:32
wi
what is the simplest case to start with i.e. 1-D euler equations ???
Old   June 27, 2008, 07:21
eugene
Thanks Vuik and Wi for your valuable information. Is there any demo code for me to have a reference. My case is indeed very simple. A 2D geometry and simply vibrating in one direction. Cheers
Old   June 27, 2008, 13:34
Harish
If you do not have any mesh deformation, you can use rigid body motion of the grid over deforming mesh or immersed boundary method. In this way you will not need to calculate the grid metrics at every timestep and would also not be required to reconstruct the grid at every timestep and it would speed up your computations. Look for papers by Steger around 1980s in AIAA journal.
Old   June 27, 2008, 14:02
eugene
Thanks, Harish. I will search these papers. By the way, I am still wanting to know whether there is any open-source code for a reference?
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 23 August 6, 2014 03:50
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM 8 April 7, 2014 11:10
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Waves halted by moving mesh Piotr Czajko Main CFD Forum 1 November 24, 2007 03:00
