I Need Source Code of PLIC method of Youngs
I want to get a source code of 2D PLIC method of Youngs for capturing interface. Would you help me? Thanks!
Re: I Need Source Code of PLIC method of Youngs
PLIC code of Prof. S. Zaleski may helps, it is more advanced that young method however very similar,
URL: http://www.lmm.jussieu.fr/~zaleski/c...-3.1.7.tar.bz2 (http://www.lmm.jussieu.fr/~zaleski/zaleski.html) good luck PS: 2d PLIC is basically easy to implement but 3D is tricky, you can assist 3D code of Zaleski too. |
To John,
Thank you for code supply. However, I'm not familiar to the code. Would you like to point me whick section in the code is for PLIC? I urgently want to know the section code for PLIC. Thanks! |
ciam.f
code is modular and if you understand algorithm (refer to Zaleski 98 JCP paper and also his JCP Note), then u could used it very easy |
Sorry, I don't understand your reference of "Zaleski 98 JCP paper and also his JCP Note".
I have found a paper "(Aulisa et al. 2003)" about the developed PLIC at "http://www.lmm.jussieu.fr/%7Ezaleski/drops.html". I don't know whether the paper "(Aulisa et al. 2003)" is the one you refer to. Could you tell me the name of the corresponding paper you refer to? |
Ok,
here is their detailed info.: 1. Volume-of-Fluid Interface Tracking with Smoothed Surface Stress Methods for Three-Dimensional Flows, Journal of Computational Physics, Volume 152, Issue 2, 1999, Pages 423-456. 2. Analytical Relations Connecting Linear Interfaces and Volume Fractions in Rectangular Grids, Journal of Computational Physics, Volume 164, Issue 1, 2000, Pages 228-237. |
To John
Well, It seems that your research work is about interface capture and you are familiar with the code. I have skimed through the 2 papers you have refered to and known the main frame of the code. However, there are some questions about the algorithm of computing alfa from volume and computing volume from alfa. So I want to directly correspond you through email for the questions about interface capture. My email address is yka8150@gmail.com. Could you send your email address to me? Thanks! |
