why should we use velocity at inlet?
Old   July 1, 2008, 07:21
Default why should we use velocity at inlet?
rean
I wonder why we use velocity inlet boundaries to incompressible flows, but mass flow at inlet for compressible flows? Could anybody guide me???
Old   July 1, 2008, 13:45
Default Re: why should we use velocity at inlet?
ag
Typically the inlet mass flow for a problem is specified as it is usually known from physical data. For incompressible flow, since the density is constant and can be taken as unity, the mass flow rate reduces to the velocity. It should also be noted that most compressible solvers use a variable set where the mass flux is one of the dependent variables. Thus specifying the mass flux at the boundary is consistent with a Dirichlet boundary condition.
Thread Tools
Trackbacks are On
Velocity Inlet BC -- Flow Reversal salihovic FLUENT 0 May 8, 2011 05:45
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues VT_Bromley FLUENT 3 February 12, 2011 10:02
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 16:35
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 08:20
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
