June 30, 2008, 08:21 |
Intake manifold analysis
I am going to simulate an engine intake manifold by star ccm+ .I have msss flow at inlet and pressure at outlet. Please answer to these questions:
1- These analysis should be compressible or incompressible? I ran incompressible analysis , and as expected I found little pressure change. But I suspect that, this may be compressible analysis. Kindly guid me for this. |
June 30, 2008, 08:39 |
Re: Intake manifold analysis
Compressible vs. Incompressible flow depends on the speed of the flow entering the intake. For Mach numbers less than 0.3-0.5(ish), I'd say you are in the incompressible range.
June 30, 2008, 10:58 |
Uh?
Intake manifolds are like musical instruments. Absolutely dominated by pressure waves. I really doubt you are doing a steady flow calc. |
June 30, 2008, 11:16 |
Mehndan,
Is this for an engine intake or musical instrument? Can you provide some more background to the problem please? JT |
July 1, 2008, 04:26 |
Hi Thanks for response. Its for engine intake. I got around 150 m/sec velocity when running incompressible analysis, thats why I doubted that, it may be compressible flow. what are your suggestion?
July 1, 2008, 05:33 |
guessing this is for an aircraft - which then raises the question of what pressure altitude are you simulating this model at, because the local speed of sound differs at various altitudes. Something that is compressible at a certain altitude, may or may not be compressible at another.
Drop me an email directly if you need further suggestions |
July 3, 2008, 05:28 |
Ahh (sound of penny dropping). I assumed you were studying the intake manifold of a piston engine.
Intake manifold analysis | alonzoo | STAR-CCM+ | 2 | July 6, 2010 04:00 |
intake manifold simulation | uday | Main CFD Forum | 6 | December 21, 2009 01:39 |
need help with manifold analysis in fluent | anil1886 | FLUENT | 0 | August 29, 2009 10:29 |
Intake manifold analysis | mehndan | Siemens | 3 | August 22, 2008 04:24 |
Modeling of a airflow in a intake manifold | Jack | FLUENT | 1 | September 21, 2003 22:22 |
