July 15, 2008, 04:14 |
DPM turbulent dispersion
Hi there,
I'm modelling a ladle with a DPM injection to simulate Argon stirring from the bottom. The problem is that the DPM particle concentration is slightly too dense in the central bottom regions of the plume, therefore overpredicting central plume velocities. These larger velocities cause larger velocity gradients and therefore larger turbulence generation (Gk). It seems that this over predicted turbulence generation causes a sharper increase in epsilon than in k (probably because errors in Gk is augmented by a greater than unity constant in the epsilon equation). This leads to another problem: the turbulent dispersion of DPM particles is calculated from a time scale 0.15k/e. Since epsilon is more overpredicted than k, this time scale decreases, causing a narowing of the plume. This narrow and more concentrated plume causes even greater over prediction of central plume velocity and the vicious cycle starts all over again. I've tried to correct this by simply changing the epsilon generation constant (C1e) from 1.44 to 1.38. It seems to work well in the SKE model for predicting the correct plume diameter, but I'm not sure about the implications of simply changing the model constants. The RNG k-e model and the RKE model require much larger changes in their model constants, and that just feels wrong. Any help would be much appreciated! |
Display Modes | |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 12:00 |
Turbulent dispersion of particle tracking in LES | mittal | OpenFOAM Programming & Development | 4 | February 23, 2011 18:01 |
Turbulent Dispersion for Coal Combustion | gravis | CFX | 2 | March 23, 2010 23:56 |
Question on turbulent dispersion force in momentum | Emmery | FLUENT | 0 | December 12, 2007 10:31 |
Lift & Turbulent Dispersion in Stirred Tank | ozgur | FLUENT | 0 | April 23, 2007 10:01 |
